i am thinking of buying a few new parts for my pc. and will most likely go with amd this time around. ( though my intel experience has been very good so far.)
i have 3 main reasons for this. faster feedback while there are transformations in the scene ( weighing, simulation and such. and texture painting.
i will wait out for the videocard because the next gen cards are right around the corner ( wildcat VP )
the parts im looking at are a
Giga byte 7VRXP kt333 motherboard
athlon xp 1800+( fan+heatsink included )
1.) anyone got anything to say about this motherboard? ive read the review on toms hardware and he says its good. but i think he also mentioned a lack of thermal control on the board. knowing how amd has had its problems with heating i am a little concerned about this.
or does the XP 1800 not suffer the problem anymore?
2.) ram. i want to get about 768 ddr.
what i want to know is how much actual real world difference there is between the 266mhz and the 333mhz. and how much of a difference registered ram does.
3.)also. when it says 32x64 or 64x64 what exactly does that mean ? does it mean that the 64x64 is double sided? what would be the difference to the user ?
weird. because there is also 32x72 and 64x72.
for now im thinking of buying 3x CRUCIAL MICRON 256MB 32x72 PC 2100 DDR RAM - OEM(REGISTERED ECC)184-Pin, CL=2.5-Unbuffered. ECC 2.5V, 6-Layers
or should i get CRUCIAL MICRON 256MB 32x64 PC 2100 DDR RAM - OEM 184-Pin, CL=2.5-Unbuffered 2.5V,6-Layers CT3264Z265.16T
which is about $14 less a piece. ( as you notice i dont want to overspend here )
or....2 of these
CORSAIR MEMORY CM64SD256-2700CX2H C2 256MB PC2700 DDR RAM 333MHz - OEM CM64SD256-2700CX2H. DDR, PC2700 32x64, Non-ECC, 184-Pin, CAS2 -Unbuffered
as you can see im not too familliar with ddr ram.
any suggestions are appreciated. thanks.
