AMD Voltaje problem
Hi guys, I have a little problem with voltage...
My configuration is AMD Athlon XP 2000+, Asus A7V266-C motherboard, Windows XP Pro.
I recently installed the Asus Probe 2 monitor, and sometimes it blinks showing an alert on Voltage 12+, when it reachs the thresold limit.
It happens when I work with Maya, and exactly after a long time of modelling (moving a lot the viewports and working with hardware shading, and that stuff). So it starts to blink, I release the mouse for a few seconds, and it stops!!!....
Is that normal?
I recently change the processor's fan (I use only AMD original fan) because a problem of heat, and the problem persists...
Thanx!
Who makes your Power Supply and how many watt is it rated at?
