Hello,
I recently had the same question and gmask cleared it all up for me. I don't know if you found out how to do it yet, but this worked for me. Make a curve and a nurbs circle. Select the circle first and then the curve. Go to Surfaces, Extrude, then the little box next to extrude. In the extrude option box make sure that Partial is checked. Click extrude and then there should be subCurve2 under inputs in the channel box editor. Do not delete the history for your extruded shape. You can keyframe the min and max values. But the problem I am still trying to figure out (did you have this too?) is that if you change the shape after it was extruded then you get wierd results(becuase it still has history)....
