I've found myself needing to do some scripting that is above my head.
I need to create a simple script to drop a ball on a flat plate and then drop another ball on to the same flat plate 1 second later. But I need to keyframe the transparency, Rigid Body Active on/off, Collision Layers, and several other Channel Box parameters. One ball falls, then later the second one appears, and falls. Eventually there would be 5 objects doing this, and selectively interact only certain objects.
The trouble is, I'm a noob with scripting and python. Would someone be able to work me through this? If it's easier to do in MEL, that would work, too.
Thanks!
