hi all,
how would you animate a fluid (not necessarily mayas-fluids) being pressed through a syringe ?!
i'm not after simulating the emptying of the syringes' body, for i will do this via mattes later on in post.
what i'm after is how to animate that drop of fluid, which will come through the needle and fall off onto the ground.
i did a few experiments with softbodies, for i wanted a poly sphere to exactly deform into the needle, while being flushed through, but it didn't work as i expected.
am i to keyframe the whole thing (maybe with help of deformers), or is there an easier way to do it ?! how about blobbies ?
btw, it's allowed to look a little exaggerated (toony), like maybe the needle deforms a little, while the drop passes through ... do i make sense ?!
hope somebody can help
