Animating a running machine track thingy!
Hi,
Im doing an animation which requires a crisp packet running on a running machine. Ive animated the crisp packet but now I have the problem of making it look as tho the running track on the machine (not sure the exact name for it) is moving.
I 1st thought of using an animated GIF but this didnt work, so Im not sure which would be the best way to do it. Does any1 have any suggestions? If u want the link below takes u to were u can download the animation to get a better idea of what i mean.
http://www.3dls.co.uk/Computer%20Animation…0Module/CAT.htm
Thanks!
3dls
UVmap your texture onto the track, scale it and repeat it (in U or V) as many times as needed in the direction the track, and then translate it (the texture) across the surface.
You could also create a loop with a curve and then spline deform a texturemapped grid to the curve.
Then all you need to do is move the grid along the curve et voila! Just remember that the grid needs to be translated in the deformation window and NOT using the translate menu in the interface on the right.
To round things off, you could apply motion blur to your track.
Hope this helps,
Peter
WOW thanks Peter!
Ive never used anything like this on XSI before but i’ll try and learn it!
Thanks again!
3dls
