I’m designing a lobster in Maya 6.0 and need to add antennae/feelers to his head. A pair of these, tapering to a point would move slowly, but not need to move too much.
Does anyone know of a simple enough way of doing this? Is there some way of adding a stroke to a curve? Or a tube tool? Sorry for the stupidity, i’ve just been learning Maya a few weeks.
Hopefully this image will help give you an idea of what i’m trying to do
Thanks a lot
A bend deformer? More control would be through a cluster deformer. These are little widgets, that can influence a part of your geometry (like Max
Thanks a lot Chris, i’ll give these a go
Or you could try using the ‘Paint effects’ presets.
Create a new scene for testing to play with.
Go to Windows - General Editors, and open ‘Visors’.
There you’ll get a number of presets.
Create a simple curve, and try ‘Metals’
Select your curve, then select one of the tube metals. (you might have to shift-click to get them both highlighted)
Then go to - Paint Effects - Curve Utilities, and select ‘Attach brush to Curve’
It then should create a tube around your curve.
One you do this you can play with the colors, size..etc.
Hope this helps.
