Hello
I am trying to make a book that animates opening. the pages in the book deform when the book opens. I'm trying to get the texture to deform too, is there any way to do this?
Thanks,-JSH3D
Once you've applied the texture, either mute the operator or freeze the object. This will force your texture to deform with your object.
I'm using shape animation using keyframes, and when I freeze it, the shape animation is removed
I guess muting the texture support didn't work? It not, then just select the texture support op, drag it above the shape animation, if it isn't already, and freeze just that.
