Can anyone point me to a tutorial about syncing an animation to sound. The official tutorial shows how to create a local variable from a sound clip but not how to apply it. I'm trying various expressions on a Brightness node but can't get it to work.
Thanks
try puy AUDIO expression into a transform xPan, then you can check the animation curve, and do whatever you want to it
thanks
Thanks, but what's the syntax, is there a reference somewhere?
put expression AUDIO into your brightness,
you can control the volum by AUDIO * 10 , or AUDIO/5 ....
say you load the AUDIO into the brightness, you can check the brightness animation curve, can modify the curve manually or using the curve converter.
Error: Backend Fetch Failure
