May 2001
1 / 6
May 2001
May 2001
Hi there
I need help regarding rendering animations. I have a scene ready also placed a camera and have animations as well. I go to render globals set the parameters for avi format set the frame start and frame end, then i go do batch render and after the batch rendering is done 100 % what i see in the avi movie is a stagant image. I want to know am i on the right track for animations and if i am where ami i going wrong and if i am not then pls help me in this. I have tried many options to see the animations but still failed.
waiting very eagerly to here form you.
THANX
  • created
    May '01
  • last reply
    May '01
  • 5
    replies
  • 940
    views
  • 1
    user
  • 2
    links
If you just want to view what it will look like.
You can do a playblast with the Render Global stats turned on.
It will take a bit... But It will let you see what is going on just a little bit quicker that Rendering out the Animation to Frames and turning it into an .avi outside of Maya.
Hope that helped,
King
H2O Entertainment
Hi gmask can you pls tell me how to do this image sequencing thing and how to later convert it into an avi movie.
and vector i did tried the playblast thing but although it shows animations but it does not render the scene i mean its as good as watching the animation in the perspective mode of the MAYA authoring environment withour effects like glass effects etc.
i have tried all the options in the render global menu, plyablast, save batch render etc. also when i want to export it into a MOV it says, cannot save file.
pls help
Use Maya fusion lite that comes with the package... Or get some other prost processing aplication like after effects.
or as a cheap alternative get quicktime PRO
hi,
to render a sequence of images just set the start and end frame, the file name, the frame /ani ext. (name.#.ext), and the image format. Render to Targa or Tiff. You can view your image sequence with fcheck. I usually just use Premiere for editing/converting later, but u can also render straight to avi, I do it all the time.
