Animation= No Avi Output?
I made a multiple frame animation and after an hour i gave up. I went to the render settings set output to avi and frames to render. Then it was only doing single frame render ><; I eventually tried a Batch Render or sumtin and the script editor said it was rendering each frame. YAY!....... But when it spent like 4 min rendering, the file size was 1kb and corrupted.
what am i doing wrong?
Check if there is another AVI file that you missed.
Hi
Chk you HDD Space first
or render as sequnce render (.tga or .iff or u can use .pic)
if u use iff or pic it will tkae very less space and qulity output
and do optimize the scene also..(chk the texture size also)
