Hi,
Even its challenging me for the past 4.5 yrs.
1) if you put ur pixel aspect to 1 it will look fine. if you put ur required aspect ratio like .9, 1.2, 1.066, 1.422 it gives the a slight antialising issue when viewed in our computer monitor. we have been sending like this only but in the broadcast it was never been a issue, so far we have done 3000 mins of output so nothing to worry about it.....
2) another issue is even if you are using pixel aspect ratio 1, when you click fit mode in ur viewer u can see the jagged edge around all the edges, then if you press home in the viewer it will look good. some times we may forget to click home before showing it to the client or big bosses.
thanks
Nishok A
