API Exporting Issue
I need someone's expertise on this exporting problem of mine.
How it works: Select a camera (animated or not is optional) >> File >> Export Selection >> File Type : .chan (need to load this script as a plugin)
Here's where the problem starts. It is able to create a .text file, however, it is not 'exporting' or writing out the contents into the text file and the file size is of zero bytes.
I am making use of the current API that it has been coded, modifying the code to add in some maya cmds
Can someone kindly help me out?
The Insert/Edit Code function screws up my code and hence please view it here : code
