hi,
while applying a fluid cache to a different size (low res) fluid container works the overalll scale of the cache looks off.
Is there anything i am missing or should i not do this at all?
i want to avoid recaching the fluid when i need a low res version.
Somebody has experience doing that?
cacheFileConverter.py and cacheFluidExample.py from the devkit give me stack overlflows in reading when i run them on simple stuff.
Apparently a known problem http://mayastation.typepad.com/maya-station/2009/06/the-maya-ncache-format.html
Anybody has some docs or insight on the file format?
And yes the ost would be better off in the fluid thread if somebody cares to move it...
