Applying Constraints To Subd (?)
Hi (newbie here) -
Can someone please confirm if Maya allows objects to be constrained to SubD surfaces? I've tried and it works for NURBS and poly sufaces, but not so for SubDs. Is there a work around or something of the sort -- short of converting my model to poly.
Thanks,
  • VH -
Are you talking about geometry constraint? Thw manual is pretty clear on this:
QUOTE(Manual)
A geometry constraint restricts an object to a NURBS surface, NURBS curve, or polygonal surface (mesh)
QUOTE(failure @ 10/22/05, 03:14 AM)
QUOTE(Manual)
[snapback]217848[/snapback]
So, theres no other way of constraing an object to a SubD surface?
make a mesh out of the subd and constrain to that!
QUOTE(Glossary :: geometry constraint)
In animation, a constraint that restricts an object to a NURBS surface, NURBS curve, subdivision surface or polygonal surface (mesh).
According to the doc, it should be possible!
Actualy theres plenty of references for this NOT working on subds! But yes i can find this page. Anyway all other pages clearly state otherwise. Bacuse this is the glossary item and not the full descriptor id be inclined to say that the glossary contains errata.
So no it should not even work. because if you take a look at the actual normal contraints page it clearly startes only curves, surfaces and heshes are possible to constrain! The description of the actual manual page superceedes whatever glossary might say
so if you look at this page
../en_US/CharSetup/geometryconstraints.html
theres a clear omission of subdivs!
but this is academic offcourse if it does not work it does not work whatever somebody might have written in the manual.
Hi, coming in a bit late here. I've got a subd and nurb object constraint. Parent/aim/etc all works fine (maya 6.01). You have to make sure though that weight is set to more then 0. Constraint didn't work for me untill I did a resetof the setting. Hope this helps
parent and aim operate on transform nodes and don't (need to) care about the type of geometry, while on other hand geometry (and normal etc...) constraint must use shape node data and would not work with subdivs.
