Attaching a deformed patch to another NURBS obj
I'm trying to put a cap on this object, but can't figure it out.....I built the obj using bevel+, which is supposed to join the surfaces & let you deform them. but the cap didn't deform with the top as I edited it....so I need to build a cap that deforms to the shape of the top & then stitch it. (??)
any advice? am I missing something obvious?
thx
Select the inner isoparm of your bevel and choose make planar
that only works with flat surfaces: if you look at the contour of the top, it is shaped almost like a boat hull.
Oh.. then it will be more difficult... Select four isoparms in the hull na ddetach them then select the edges isoparms at the top and then use surface->Boundaries
hmm, that's pretty messy too & doesn't follow the contours at all. thx anyway though, I wouldn't have thought of that!
what I'm trying now is to build a surface by snapping some profile curves ( well, their endpoints at least ) to the CV's on the top bevel, then lofting them together. this should follow the shape of the top......then I can project the top isoparm onto this surface, trim, and hopefully stitch?
edit
actually, what am I thinking? all I have to do is add some the correct # of isoparms to that planar surface I have, then snap their cv's to the ones on the boat-hull shape. then stitch....?
you cannot stitch or attach any surface that has a trim for an edge.
