Rendering CG shots in Maya, and compositing in AE.
Doing the basic "Assembly" of the layers in AE is easy, but time-consuming because it's always the exact same settings, and there are so many shots.
So I'd like to automate this a little bit...
Ie. I'd like to set up a "typical" project, with basic settings dialed in, layers stacked in the right order, etc etc -- and then be able to simply replace the footage layers automatically.
Ie. automatically meaning, NOT by clicking "replace footage" on each and every footage item, and having to manually fish out the proper layer in the file browser. I have hundreds of shots, with 8-10 passes per shot, so that is too time consuming.
I am thinking AE scripting might be the answer, but I'm not familiar with JSX at all...
My folder structure looks something like this:
Any solution is good for me, though the best would be a JSX script that brings up a little window, with two input fields:
Old: S15A001
New: S15A002
and a "replace" button...
I thought of doing a search & replace in the .aep file itself... I do this with other apps sometimes that use ASCII file formats, but AE doesn't, so it doesn't work.
One more caveat: not all shots are the same length, or start at the same frame. Some TIF sequences run from 1-20, others from 150-190, etc etc.
Again, I'm totally ignorant of JSX, so I don't know how big a deal this would be to write. If someone can point me in the right direction, that would be great.
Any cheats / workarounds are also welcome. It doesn't have to be pretty.
