hey everybody - i wanted to know if anybody knows about a script that immitates the function of autoTangent in 3d MAx - because its getting realy annoying to convert to spline and then fight the maya graph in order to assemble a normal movement - thanx a lot
yeah the auto tangent thing in max is actually kinda cool. i'm not aware of anything that directly simulates that effect, but check out a script called: tangent works. its pretty helpful for making tangent adjusting a much less painful.
hey man thanx for d tip - but i couldnt use ur script - i installed the zzGraphFilter and when i sourced it - nothing happened - tell me how should i work it -thanx again
you've gotta run the script then... type zzGraphFilter.
sourcing it only loads it into memory. unless of course its a script that isn't written using procs (bad idea in IMHO).
