Can anyone explain how averaging works in the math operations? in what situation would you use it?Thanks,Jon
hello
the most useful feature is scale, for fit your animation whit your sound track.
the random key , is very nice for make fast caotic animation.
Averaging smooths out extreme keyframes (smooths out your animation curve) over the amount of frames that you set. You may use it when applying tracking data from one source to another source. You may want the same motion from the original data but just a little smoother not so frenetic, you might average the data over 4 frames or you could just average one channel to give a subtle variation. Averaging would probably be used more creatively than technically.Hope this sheds some light.regards Kylie : )
