I tired to get this to work and it crashed Maya. You need to use the movie node instead of a file node. In either case you should use and uncopressed codec for the movie. In general it is a bad idea to use movies.. you should an image sequence. They are many problems that you may encounter using movies for textures or output.
If you need info on using image sequences do a search for image sequence.
---a note from our sponsor---
Have you tried searching highend3d?
www.gmask.com
