Hello!
I've written a custom locator that changes its shape depending on a string in an attribute called "mapTyp".
I've compared the speed to a regular locator and it's much much slower. Is there some way to make this more efficient? Eventually I'll need hundreds of these.
class MapLocator(OpenMayaMPx.MPxLocatorNode):
    mapTyp  = OpenMaya.MObject()
    name  = OpenMaya.MObject()
    beschreibung  = OpenMaya.MObject()
    datum = OpenMaya.MObject()
    pathCoords = OpenMaya.MObject()
    media = OpenMaya.MObject()
    drawLoc = OpenMaya.MObject()
    drawText = OpenMaya.MObject()
    def __init__(self):
        OpenMayaMPx.MPxLocatorNode.__init__(self)
    def boundingBox(self):
        p1 = OpenMaya.MPoint(-1,-1,-1)
        p2 = OpenMaya.MPoint(1,1,1)
        return OpenMaya.MBoundingBox(p1,p2)
    def getAttr(self, attrName, typ = 'string'):
        obj = self.thisMObject()
        depNode = OpenMaya.MFnDependencyNode(obj)
        plug = depNode.findPlug(attrName)
        if typ == 'string':
            return plug.asString()
        if typ == 'bool':
            return plug.asBool()
    def draw(self, view, path, style, status):
        doDraw = self.getAttr('drawLoc', typ = 'bool')
        if not doDraw:
            return
        mapTypText = self.getAttr('mapTyp', typ = 'string')
        nameText    = self.getAttr('name', typ = 'string')
        beschText = self.getAttr('beschreibung', typ = 'string')
        drawText = self.getAttr('drawText', typ = 'bool')
        view.beginGL()
        if mapTypText in ['ereignis', 'text']:
            self.drawEreignisType()
            if not drawText:
                return
            glFT.glPushAttrib(OpenMayaRender.MGL_CURRENT_BIT)
            glFT.glPushAttrib(OpenMayaRender.MGL_ALL_ATTRIB_BITS)
            if mapTypText == 'ereignis':
                glFT.glColor4f(0, 1, 0, 1)
                drawText = nameText
            else:
                glFT.glColor4f(0, 1, 1, 1)
                drawText = beschText
            if status == OpenMayaUI.M3dView.kLead:
                view.drawText( drawText, OpenMaya.MPoint(0.5,0,0), OpenMayaUI.M3dView.kLeft )
            else:
                view.drawText( drawText[:3], OpenMaya.MPoint(0.5,0,0), OpenMayaUI.M3dView.kLeft )
            glFT.glPopAttrib()
            glFT.glPopAttrib()
        elif [other types.............]
        view.endGL()
    def drawArray(self, pointArray):
        glFT.glBegin(OpenMayaRender.MGL_LINES)
        for i in range(len(pointArray)-1):
            x1,y1,z1 = pointArray[i]
            x2,y2,z2 = pointArray[i+1]
            glFT.glVertex3f(x1,y1,z1)
            glFT.glVertex3f(x2,y2,z2)
        glFT.glEnd()
    def drawCircle(self, center = (0,0), radius = 0.5,step = 4, rotate = (45,1,1,0)):
        glFT.glRotatef(*rotate)
        glFT.glBegin(OpenMayaRender.MGL_LINE_LOOP)
        for i in range(0,360, step):
            degInRad = math.radians(i)
            glFT.glVertex3f(math.cos(degInRad)*radius,math.sin(degInRad)*radius, 0)
        glFT.glEnd()
    def drawEreignisType(self):
        self.drawCircle(rotate = (45,1,1,0))
        self.drawCircle(rotate = (-90,1,1,0))
        return
Any help would be much appreciated!
