Whenever I try and asign a texture to hair, it crashes.
Whenever I try to render 'Geometry' hair, it crashes.
Is there blood coming out of my ears?!?
Knick Knack
For the texture to be projected on the hair, you need to first assign it to the gemetry and create a texture support. Then transfer that support into the hair, using the transfer map button.
The only thing I could think of for the gemetry failing is that you might have too many hairs and it's crashing the computer.
geometry hair needs a lot of ram. the higher hair count, the more ram you need.
Volume dosent need more ram, it will just be slow with more.
Mike
i dont think he means render the hair as geometry.just that the texture requires a texture support to project it onto the underlying geometry (eg, the skull)Jolly good
