Dont know if you can do all you work in maya 2009 because since this version there is a feature called "Render Passes". Its commonly used for creating separate images out of different color passes, even on a per objcect base via contribution maps. You should have a look at it. With it you could create an additional render layer, assign all the objects you want the lightmaps from and create a material override with your shadow shader for this special layer (the override material only applies to your objects while rendering this special layer, so no reassign of original shaders needed).
A quick setup would look like:
select all the objects you want to have lightmaps from, then switch to render layer and choose Layer->Create Layer from Selected
go into Hypershade window and right click on your shadow shader and set "Assign Material Override for layerX" (and make sure that your new render layer is selected, otherwise this option wont appear)
everytime you now start baking lightmaps only make sure that in your render globals the current render layer is set to your override layer, done.
PS: if stuck with maya 2008 why do you bother with reassigning the original shader? Why not saving the scene, assigning the shadow shader, rendering out the lightmaps and reset the scene to saved state?
PPS: aah i see, vertex baking. So i am not even sure if the upper approach would work, i have never used vertex baking so far. So i would suggest that you use a little script that writes each objects material name into a custom string attribute before assigning the bake shader, then reassign the original shder with a second script after baking.
proc writeMatNamesToObject()
string $selList[] = ls -long -allPaths -dagObjects -shapes -sl;
for($obj in $selList)
string $SG;
string $depNodes[] = listConnections -destination 1 -plugs 0 $obj;
$depNodes = stringArrayRemoveDuplicates($depNodes);
for($node in $depNodes)
if(nodeType $node == "shadingEngine") $SG = $node;
if(! attributeExists "dxSG" $obj)
addAttr -ln "dxSG" -dt "string" $obj;
setAttr -e-keyable true ($obj + ".dxSG");
setAttr -type "string" ($obj + ".dxSG") $SG;
proc assignOrigMat()
print($obj + "\n");
if( attributeExists "dxSG" $obj)
string $SG = getAttr ($obj + ".dxSG");
print("material: " + $SG + "\n");
sets -e -forceElement $SG $obj;
