"baking" clipmaps to actual geometry?
Hi again,
This is probably futile, but is it possible to convert the effect of a clipmap (alphamap) into actual geometry?
I.e. if I have a plane, and use an image to mask out whats invisible and whats not, using the alpha-channel, would it be possible to "bake" the result into the plane, so that the geometry only exist where the alphachannel is opaque, and the transparent areas gets trimmed. I realise, as I write that this might be difficult, but it would be a great feature. Of cause it could not respect semi-transparent areas, but it should respect animation.
thanks, T.
Umm... yeah it would probably be possible ableit abit tedious to implement. i would imagine it would be easier to do on a Nurbs surface... and almost impossible/hard on other types of surfaces.
I woukd do this manualy offcourse but yeah a script/plugg could be usefull. But ist kindofa heavy operation for multiple reasons.
What you would do is to cut up the surface into pixel sized squares and then delete the ones that are black on the map! The results could probably be rationalized a bit so that parts of the object that fall outside of this dont need to be touched. But noone has done this as far as i know.
And it is in fact its easier to make the clip map changes into the depthmaps themself, by manualy rendering them before usage.
Right, an automatic method is probably out of the question. Back in Alias there was a function that would actually take an image, and based on it's values, project curves onto your surface. I guess that never made the transition to Maya However, as a hack, give a nurbs surface, simply draw a Curve on Surface where the alpha is, then trim out those areas. Or on a poly surface, use the split tool to surround the transparent area, then delete the faces. I could have sworn I saw a plugin some time back that recreated that Alias featuer in Maya... maybe it was a dream....
Converting the alpha into a path can be done in photoshop then just export it as AI paths and import into maya and project from the light view... (might require some math)
But as i said you can get this simpler by making the shadows ina prerernder script with some simple shading networks... At ann acceptable levell easier.
