Ball Movement On A Plane
How to simulate a ball movement on a plane using MEL with given acceleration, velocity and distance
describe more, the vaues descibed are the derivates of each other each of them alone can describe the motion. Do you mean that velocity and distance are just locked as initial conditions?
QUOTE(Joojaa @ 02/28/09, 04:02 AM) [snapback]301938[/snapback]
the ball will move with different input of velocity and aceleration and distance is show how much it has move.
Well thing is only position has any defined meaning in reality. the others are derived values. While thay have meaning they are inter linked to position. And theres no real nice way fo doing this, truly doing it is more trouble than its worth. But yes you can do it just numerically integrate the veelocity. Or 2 times for acceleration. But seriously doing this in maya will not be nice. Or then you end up with having something you can solve but can not scrub in maya.
However plaease note you can either have input for 1 static start position and velocity. or one static start position and satart velocity, and acceleration. You can not have 2 graphs of velocity and accereation since it makes no sense.
Use rigd body simulation, or expressional integrators. But seriously DONT do this, it has very little use for animation.
