Could you get the light's manipulator to show? If not then it would more than likely be that your ShowManipDefault parameter is set to something other than None. Select the light then select Modify | Transformation Tools | Default Object Manipulator | None. Set the viewport to the light then select Show Manipulator Tool.
[ D A V I D G O U L D ]
email: davidgould@davidgould.com
web: www.davidgould.com
