Hello !
It’s a charactere(Barney) for shape test i try to make it latter ![]()
It’s kain the hero of little movie wich i try to make ![]()
I 'll wait for critique bye !![]()
whats the info in this ?
Software? Nurbs / polys ?
If its polys whats the count.?
Nurbs , like to check the wireframe..
pretty neat so far, that guys mouth is pretty narled.
It’s poly modeling.
Kain : About 47864 triangles (20 000 polys) for the hight-res and about 13 302 triangles for the low-res.
I optimise this at the end. bye !
hats off man. thats some serious poly modeling.
What software was used ?
I really like that narled look of barney, the face on Kain is not as dynamic , kain looks much less alive I guess you could say.
Barny seems well weathered, what sort of character is he ? A miner? Piolet?
Your right
kain looks much less alive,thank to underline it,i’m going to arrange that(It’s the basic expression shape )
i’m going to try to finish that when i shall have time.thx ![]()
yea certianly. Kain just doesn’t match the complexady of Barny when put up next to each other.
Barny out shines him.
I wouldn’t say that. Barny is a lot older than Kain I’d guess…hence he’s bound to have a lot more expression in his features (life lines, etc) As for detail…i think Kain probably has just as much except they’re found in other areas rather than the face itself. I think they’ll look fine together once they’re textured and Kain has some nice hair. More, finer, detail and facial interest can be added to Kain via diffuse/bump maps and help balance it all out as a whole. I think as long as Barney’s costume isnt as elaborate as his face they could look nice together.
really like these two models Pixelator…cant wait to see the finals
gorgeous
Beautiful models-
I would be privileged to see your wireframes so that I might understand just how you managed to get so much complexity in on Cain’s face. I would love to incorporate this in my own workflow.
Thank You and please keep up the good work!
Thx for your critik
here a wire frame
I put samples of old face modeling research if somedy are interest here the link :
http://www.multimania.com/razorjakfr/Pixopath/
Bye ![]()
Only one thing I can thing of to say “WOW”. Very nice work there. I like looking at your wireframe also. You show an understanding of not only the form of the face but the layout of the mesh as well. My hats off to you.
Cyphre
great what about the other one?
the other he stated as polygon based..and well, a ply mesh doesn;t show much ![]()
anyway .. what software is that you;re using? i don;t see it listed.. i love that first head. He looks like he has an intire history to him .
oh and GEEZ man, the stuff on your server is NICE>
thanks for sahring. if you get some nicly hooked up finals..submit to the HIGHEND gallery that is starting up.
I use to create my model, Max. But,is the same things with the others.I often use to work maya(with connect to poly shape ) and xsi(subdivision),it’s basicaly the same things (to modeling of course),it’s simply tools
Because of that i say nothing.But you certainly know that
.bye
acualy, I was only wodnering becosue of the render.
I always like to know what tool was used simply to figure out the methoud of render.
thanks for the info , certainly it is the same process to do it in another program .
Yes you’re right ![]()
I use max standard render , 4 omni with 1 spot bye
(excuse my english)
Very elegant modelling and nice texturing as well. The only thing that is not quite up to your high standard are the ears. You really have a feeling for form and character. More of this stuff!
Draugr
Meanwhile the standard of work shown on the boards continues to rise .. and rise.. and rise .. and rise. Personally I prefer Barney but not neccessarily because the modelling appears more detailed but because he seems far more characterful and alive. Both are terrific to me ![]()
