Hi,
I wanted to know about any clavicle rig method which is error free and realistic.The method i am using is a multiple joint clavicle setup which is driven by one joint Ik chain(with an Ik Handle) with a following Fk single joint chain,which is connected via multiplyDivide node(makes Fk joint chain adjustable) and some locators.
Then i have a scapula which is driven by this Fk.Finally all this setup is parented under one joint which is controlled by Arm autoClav joint and Fk Arm via another mutiplyDivide node which is orient constrained to these chains.
The problem is i am getting "cycle" errors.
Please help if you guys know of any more stable and less complex setup with effective deformations.Thanks.
