Birail problem (2)
Hi,
I'm having some problem with bi-rails. I have two square-like curves positioned next to each other and then one curve between them like this:
http://www.hlarsson.com/birail/birail_problem1.jpghttp://www.hlarsson.com/birail/birail\_problem1.jpg
What I want to do is to pick the short curve as profile and the two large rectangular curves as rails. But when I do this I get the following result (there is a gap in the surface). Any ideas why?
http://www.hlarsson.com/birail/birail_problem2.jpghttp://www.hlarsson.com/birail/birail\_problem2.jpg
  • Henrik
maybe the rectangular curves are not closed or have different start/end points..
why dont you try lofting the recangular curves, think thats a better approach to what you are trynig to achieve
so why are you birailing this? seems like a simple loft to me...
you're right, it was kinda stupid to use birail, don't really know why I wanted to do that. As you say, it's better to use loft and then modify the surface to the shape I want.
Thanks for your replies!
