Need a Birth Matt capable Particle system for after effects. The Final Effects, Studio Effects and Adobe particle systems do not support using a birth layer (where particles will be born only on areas of >0 grey value.
Does anyone know of a particles plugin that will allow me to do this? For instance, the 5-D Particles plugin for FLame/Inferno is perfect for my needs. I need one for After FX.
I dug fairly deep into the Particle Playground. However, from my preliminary explorations, the Particle Playground allows you to use a layer as particle source, but not as birth mat. Layer Exploder? That rings a bell. I'll look into it some more.
The best I have found (and still inadequate) has been the DigiEffects Delerium package. Even with these fairly impressive plug-ins, control of birth and death of particles and directional forces is practically omitted.
Ok. I played with Layer Exploder in Particle Playground and it works. Just works... Control is severely limited. It's also the slowest plug-in I've ever suffered with... Most glaringingly, no birth and death parameters, and no turbulence forces.
Can Maya do particles born from a texture? I'm sure it can! But on my production schedule, there's no room for CGI.
haah acualy i have asked about that and ..well. no as far as i can tell. I'd love to be able to use Maya with a birth texture and a goal texture to make the particles clump in gretter numebrs and stick harder in dark areas vers white ones..blows my mind that it doesn;t seem to be bale to do that. Seemed basic till i went looking for it during my tests to make a splatterd blob stick and then melt off somthing.
