QUOTE(rueter @ 03/20/07, 05:17 PM) [snapback]262571[/snapback]
Correct, Nuke is optimized for floating point processing so all images are converted in the Read node. No need to bother with lower bit depths.
Yes, understood, but the issue isn't comping in 8 or 16 bit, but knowing the bit depth of the footage prior to the promotion to float. If it was irrelevant we would all work with 8 bit files. It's important to know that your proxies are 8 bit as well, if that is the intention. So a quick way of identifying the bit depth of the source footage is important IMO. All it needs is an extra line in the read node info, near the top so that you don't have to scroll down. Or better yet, steal it from (gasp) Shake, where if you mouse over the filein, it tells you in the status line.
Respectfully
Michael
