I’ve run into a problem with a blend shape. One of the target shapes for the blend is a polygonal mesh controlled by a skeleton (used to deform that particular mesh shape). The skeleton is initially translated off to the side to keep it out of the way of the other shapes (translating the skeleton moves the associated mesh along with it). The problem is that when the mesh shape associated with the skeleton is added in as a target to the blend shape, the translation of the skeleton appears to be added into the blend shape as the target shape’s weight is incresed. The result is that the blend shape begins to TRANSLATE towards the skeleton’s position. This doesn’t happen with my other mesh shapes which aren’t under the influence of a skeleton and that are moved “off to the side” directly. I’ve tried changing the “Origin” setting (user, loca, world) to no avail. Does anyone have a suggestion on how I might be able to get around this problem?
Many thanks!
