Hi guys.I've got a problem.
A blue wireframe that doesn't go away.I can I remove it?
Cheers.pit
did you do a smooth proxy? At any rate my guess is that if you go into leaf mode you shoudl beable to select this and turn it off or delete it
I transformed a polygon to sub-D. Then again to polygon for a couple of changes and then back to sub-d.That might have caused the blue wireframe to stay. Could you please explain what leaf mode is?
leaf more or less equals child in hierarchal terms .. there are three icons that generally appear under the menu bar where it says window..one is for selecting the root andon it's right is one for selecting leafs
