HI,
Even i have faced these Banding Problem. Banding can be in your image or your image may be fine, it can be because of the monitor also, if the monitor is only 8-bit.
how to check whether its an image banding or Banding is because of monitor? Simple... just check which channel is showing the banding very much that channel on in ur viewer, introduce Brightness node and reduce the value (.25), then put blur node with value 0( just to break concatination), introduce another brightness node and give value4, if the banding has grown up or changed, its an image Banding, in othercase, the banding looks the same its because of the monitor.
i have used Filter/Grain node with the value of .2 in size and density, you can increase according to your sc.
thanks
QUOTE(zem @ 11/22/07, 02:26 AM) [snapback]276855[/snapback]
kinda hard to give sound advice without knowing more, so if you can upload a sample file somewhere and post the script i'm sure you get more info.
but if it's really a banding issue, yes, usually increasing the bit depth will fix that ![]()
++ chris
