Okay I asked the dept and so far have these replies
__________________________________________
tracker nodes and stabilize are the obvious ones
although we have found BOUJOU tracks to be slightly flaky when used direct in a stabilize node, i.e. they just stop working for no apparent reason ... work around appears to be import the track into a track node and reference it to a stab. node.
some things that would help with the tracking in the interface would be
view selected tracks/predictors/locators only
an ROI feature as we cant playback the sequence with the trackers ontop in anything approaching real time ... perhaps something like 3DE where you can view a realtime playback of a single tracker with the image stabilized around it
_______________________________________________
seriously though, why not just make it a choice in boujou as to what you want to export? pull-down list of tracker, cornerpin, matchmove, move3d, etc?
...or to simplify it, just a choice between a (1 or 4 pt) tracker node or Move3D..
________________________________________________
