Bringing up the interactive texture manipulator again
hey all,
well i've used maya for a while now and this seems simple but i havent figured it out. when there is a texture applied to a material and that materials uv's are mapped it automatically brings up a real handy texture manipulation tool. trouble is i cant figure out how to bring it up again without remapping the uv's. everything it does can be accomplished in the attribute editor of a 2dplacement node, but its just not handy at all. this would be useful for game stuff where tiling textures are common
thanks for any help
casey
If you select the UV projection in the channel menu and then press T, it should bring up that manipulation tool. Hope that helps.
as stated above.. but one note:
if you have delete history toggled on or decide to delete history on the model you will lose the option to call up the manipulator tool.
i've left delete history on.. and found myself without a manipulator tool in the past....
