Bvh Feet
Hi, I am using motion capture to produce a lot of animation in a short time everything looks great except for the feet that goes through the floor sometimes. The problem BVH only has an ankle joint and not a ball joint. The person being recorded obviously has this ball joint in the foot and the rig I want to use must also have this so that I can get a nice roll of the floor like a reverse foot. I thought the best way to do this would be to use a reverse foot and limit the y translation of joints to 0 this works to an degree but not perfectly the foot still wiggles on the floor. No I am thinking the best way would be to detect if the foot is close to the floor (would also like to be able to set this manually if the detection of the floor is not correct in certain areas) and if it is let the toe part off the foot not move at all and just wiggle it between the ankle and the ball joint. I would aprecheate any inset on this matter please.
You may be able to create a condition node, and hook up a locator to it that's positioned at the floor's level. Then, the if statement could control the Y trans of the joint. Just say, If, the joint's Y translation is less than the locator's, then the locator's Y trans is the input for the ankle joint. Or something like that. I don't know if it'll work, but you can try it...
