Cache Time Shift
I have a cached fluid and I want to move forward in time by one. Duncan has said a few times how to mess with the connections between fluid cache and time. But I never quite understood, and until now had a need. The cache isn't connected to time just to the fluid. I can't change the time node, b/c the rest of the scene needs to stay the same. I need to jus tshift the cache forward my one. Any help anyone? Thanks!
(Hmm possibly make a new time node and connect the fluid, which is connected to the cache, to that?)
QUOTE(destruct007 @ 10/24/05, 07:31 AM)
[snapback]217978[/snapback]
I love how as I'm posting the question, actually editing a spelling mistake, I re-read my post and added the above... I was trying different things before, just didn't try that one and of course...
Yep that did it. Geez.
QUOTE(destruct007 @ 10/24/05, 07:38 AM)
[snapback]217979[/snapback]
destruct could you explain a bit how to "disconnect" from time and reonnect to another time node? just for us maya newbies or is it as simple as disconnecting any node in maya? if i read how to connect/disconnect nodes in the manual is it equally aplicable to fluids?
QUOTE(chesterjoe @ 10/24/05, 03:55 PM)
destruct  could you explain a bit how to "disconnect"  from time  and reonnect to another time node? [snapback]218036[/snapback]
createNode time;
connectAttr -f time2.outTime fluidShape1.currentTime;
Duncan
QUOTE(DuncanBrinsmead @ 10/24/05, 04:01 PM)
createNode time;
  Duncan
[snapback]218038[/snapback]
Thanks again sir
