He he,
Yes as I said I was extremely tired and not thinking?
As Campbell has suggested:
//--snip snip-----------------------------------------------------
// Alias|Wavefront Script File
// MODIFY THIS AT YOUR OWN RISK
// Creation Date: 2001
// Author: Duncan Brinsmead( from a method suggested by Jos Stam )
// computePolysetVolume
// None.
// Prints the total volume of all polysets on the pick list.
// For accurate results the geometry should be closed, with no
// holes or minimal gaps and no interpenetrating surfaces( such as
// as two overlapping spheres ).
// The method uses the divergence theorem:
// int_{vol} Div(f) dV = int_{surf} Dot(f,n) dS
// To use it to compute volumes set f=(0,0,z), you then have
// Volume = int_{vol} 1 dV = int_{surf} n_z(u,v) du dv
// Where n_z is the "z" component of the normal to the surface at the parameter value (u,v).
// If you only have triangles then the formula reads:
// Volume = sum_{over all triangles} (z0+z1+z2)/3*n_z*A
// None.
// // Create a poly cube and find its volume
// polyCube;
// // Result: pCube2 polyCube1 //
// computePolysetVolume;
// // pCube3 faces = 6 //
// // TOTAL VOLUME = 1 //
global proc float triangleArea( float $v1[], float $v2[], float $v3[] )
float $c1[] = crossProduct( $v1, $v2, 0, 0 );
float $c2[] = crossProduct( $v2, $v3, 0, 0 );
float $c3[] = crossProduct( $v3, $v1, 0, 0 );
float $vec[3];
$vec[0] = $c1[0] + $c2[0] + $c3[0];
$vec[1] = $c1[1] + $c2[1] + $c3[1];
$vec[2] = $c1[2] + $c2[2] + $c3[2];
float $area = sqrt( $vec[0]$vec[0] + $vec[1]$vec[1] + $vec[2] * $vec[2])/2.0;
return( $area );
global proc float quadArea( float $v1[], float $v2[], float $v3[], float $v4[] )
float $a1 = triangleArea( $v1,$v2,$v3 );
// float $a2 = triangleArea( $v3,$v4,$v1 );
float $a2 = triangleArea( $v3,$v4,$v2 );
return( $a1 + $a2 );
global proc float computePolysetVolume()
string $pobjList[], $pobjListDup[], $pobj;
$pobjList = `ls -dag -sl -type mesh`;
if(size( $pobjList ) < 1 ){
error( "no polygon objects selected for computePolysetVolume." );
return 0.0;
$pobjListDup = `duplicate -rr $pobjList`;
select -r $pobjListDup;
FreezeTransformations;
int $obj, $i, $k;
string $normalInfo[];
string $curFace;
string $ni[];
string $verts[];
float $nz;
float $v1[3], $v2[3], $v3[3], $v4[3];
float $A;
int $numFaces[], $nVerts;
float $totalVolume = 0;
for( $obj = 0; $obj < size($pobjListDup); $obj++ ) {
$pobj = $pobjListDup[$obj];
$numFaces = `polyEvaluate -f $pobj`;
print( "// " + $pobj + " faces = " +$numFaces[0]+ " //n" );
for( $i = 0; $i < $numFaces[0]; $i++ ){
$curFace = ($pobj + ".f[" + $i + "]");
$normalInfo = `polyInfo -faceNormals $curFace`;
tokenize $normalInfo[0] $ni;
$nz = $ni[4];
$verts = `listAttr $curFace`;
$nVerts = size( $verts )/4;
float $val;
if( $nVerts == 3 ){
$v1 = pointPosition( $pobj + "." + $verts[0] );
$v2 = pointPosition( $pobj + "." + $verts[4] );
$v3 = pointPosition( $pobj + "." + $verts[8] );
$A = triangleArea($v1,$v2,$v3);
$val = $A * $nz * ( $v1[2] + $v2[2] + $v3[2] )/3.0;
} else if( $nVerts == 4 ){
$v4 = pointPosition( $pobj + "." + $verts[12] );
$A = quadArea($v1,$v2,$v3, $v4);
$val = $A * $nz * ( $v1[2] + $v2[2] + $v3[2] + $v4[2])/4.0;
$totalVolume += $val;
print ("// TOTAL VOLUME = " +$totalVolume+ " //n");
delete $pobjListDup;
select -r $pobjList;
return $totalVolume;
Enjoy,
