Callback mechanism in MEL
Hi,
Does MEL supports directly a simple register callback mechanism?
What I am looking for is to have a variable that when it changes (by some other process or function) it calls a set of registered callbacks and passes an arbitrary number of parameters (ie float, strings, or arrays )
Thanks
Carlos
create a node, any node.
add an attribute, a float/int attribute
create a scriptJob to monitor changes to this attribute and register the appropriate call back in the scriptJob command.
please refer scriptJob docs for specifics.
