make a heads up display. Heres a quick example (meant for you to modify execute in script editor)
global proc string[] showStringAndTimecode (string $string,int $timeBase)
string $build="",$timecode[];
int $time,$temp,$times[]={60*60*$timeBase,60*$timeBase,$timeBase};
$time=currentTime -q
for ($each in $times){
$temp=$time/$each;
$time=$time-$temp*$each;
if ($temp<10)
$build+="0";
$build+=($temp+":");
if ($time<10)
$build+="0";
$build+=$time;
$timecode[0]=$string;
$timecode[1]=$build;
return $timecode;
headsUpDisplay -removePosition 0 0; //clear the previous one
headsUpDisplay -section 0
-block 0
-blockAlignment "left"
-blockSize "medium"
-label ""
-dataFontSize "large"
-command
//set your text and timebase here!!
"showStringAndTimecode(\"Scene 12, Shot 2\",24)"
-attachToRefresh timecode;
expression -n "hudRefresh"
-s ("headsUpDisplay"+
"-refresh timecode;")
-o "" -ae 1 -uc al; //make sure it refreshes duirng playback.
