Can someone check this?
I'm trying to set keyframes at various times on the timeline on various objects.
It works, but when iterrating over the "ls -sl" arry there's an extra object that comes up at the end that has no name . In fact, when i try to print the arry index of that object it says "no object matches name".
The problem is that the object causes the keys values of that object to be set on all other objects.
Here's the code:
string $objList[] = ls -sl;
float $curTime =currentTime -q;
float $maxTime =playbackOptions -q -maxTime;
float $minTime =playbackOptions -q -minTime;
int $keysetTime = 30;
int $firstEndTime = 480;
int $otherEndTime = 580;
  setKeyframe -time $minTime    -value       0  ($objList[0] +".rotateZ");
  setKeyframe -time $firstEndTime -value -180  ($objList[0] +".rotateZ");
  setKeyframe -time $minTime  -value   0  ($objList[0] +".translateY");
  setKeyframe -time $firstEndTime -value 20 ($objList[0] +".translateY");
  setKeyframe -time $minTime     -value   0  ($objList[0] +".translateX");
  setKeyframe -time $firstEndTime -value 10 ($objList[0] +".translateX");
   print( $objList[0] +" "+ "time" +$minTime +" "+"Value" +"n" );
   print( $objList[0] +" "+ "time" +$firstEndTime +" "+"Value"+"nn");
int $i;
for( $i =1; $i <= size( $objList ); $i++)
setKeyframe -time $keysetTime -value 0 ($objList[$i] +".rotateZ");
setKeyframe -time $otherEndTime -value -180($objList[$i]+".rotateZ");
setKeyframe -time $keysetTime -value 0 ($objList[$i] +".translateY");
setKeyframe -time $otherEndTime -value 20 ($objList[$i]+".translateY");
setKeyframe -time $keysetTime -value 0 ($objList[$i] +".translateX");
setKeyframe -time $otherEndTime -value 10 ($objList[$i] +".translateX");
  print( $objList[$i] +" "+"time"+ $keysetTime +" "+"n" );
  print( $objList[$i] +" "+"time"+ $otherEndTime +" "+"nn" );
  $keysetTime = $keysetTime + 30;
  $otherEndTime =$otherEndTime + 100;
I figured it out.
Thanks
