I was wondering if you can buy Maya, and install it onto 2 different computers?
Of course. You think companies that work with Maya buy 100 copies of maya 7000$(or is that 14000, not sure) each?
Well actually theres lots of companies with a a hundred or so maya licenses.
Well it depends on HOW you buy maya. Whan you buy your asked for what licensing sheme you would like to use.
Node locked, dongle floating licence or even multiplatform licence (you will need support for this). If you specify nothing you get a node locked which only works on one computer. For a small firm the dongle is okay but for a bigger one the floating server is better.
Maya is licensed per computer, being locked to hardware (whether a physical dongle, or to the network card ID) so you cannot install with one license to two computers (like most softwares authorize for 1 laptop +1 workstation).
What you can do is use an removable hardware lock (the official dongle or an external USB network interface) to be able to move your license from one computer to the other ... assuming you can only use 1 computer at a time.
For rendering Maya comes with a license that authorize you to install maya on up to 99 computers per license ... but you only have access to the rendering components with command line, no UI ...
For Mental Ray it's again different, MR coming with "satellites" rendering licenses ...
QUOTE
Yes, commercial companies do buy licenses for each workstation used (or have a number of floating licenses accessible) but when you are called Rythm and Hues or Dreamworks, I suppose you can negociate a discount when buying 100 licenses .... which by the way cost 2000 $ for the complete (7000$ is for unlimited ...).
That's why commercial companies charge a lot of money per hour, (and are fed up having to compete with companies-in-the-garage using illegal software and breaking the market) ....
But if you have bought your license, you should know the price, isn't it
Guyb
Guyb.
Actually the price varies depending on your geographic location!
Indeed, with prices in Europe being higher than in the US despite the change rate !!
And on top, local authorities did charge us "import taxes" even when we ordered through the (at this time Alias) european website .. Oh they just forgot to mention than the CD and booklet will come from the States ... Must be too expensive to make CD's in Europe ...
Alias was one of the worse commercial company (tech. support, licensing restrictions, pricing ...). I don't know what the situation is now with Autodesk, I just hope it improved a little bit.
Guyb.
Yes basically maya used to costs 1/3-2 times more everywhere else except engand and states.
