The subject should be descriptive enough, but my question is: why?
I have an EVGA GeForce 9800 GTX+. Not the top-of-the-line, but definitely good enough to have me concerned why nothing along the lines of PaintFX or any bump/normal maps are showing up in my renders.
Of course, Software has no issue getting the render done, but I can hardly afford the time it demands for a single frame.
If my card is incapable of certain things, I hope to god there is a way I can mix both hardware and software for the job…
yeah.. I’m not really surprised you are having this problem with hardware rendering and this card. I mean you can get away with alot on the cheaper nVidia cards but in the end they are unsupported and you’ll probably need to get a Quadro.
Are you saying there was a level of compatibility harmed?
Is there any compromise here…? I don’t have the money to be
tossing toward a Quad. I barely had enough extra for this card.
The card you bought is not qualified so what you are seeing is the result of that.. not all features work correctly.
A quick look on ebay and I see alot of used Quadro cards.. that will be your best option for a compromise. Otherwise you’ll just have to wait for the software renders… so you have two options time or money.
That’s a shame. Alright, thanks. Quick final question, mildly off topic… It’s safe to have two different GPUs in at the same time, right? Do they have to be the same model if I use more than one?
The other one will be disabled, anyway i doubbt you will find a mobo that fits them both.
PS: bit about quadros be carefull just because its a quadro AND its qualified does not mean its a good gard. SO fist chek that that quadro si on the qualification, then chek if it has any known issues. Then chek that ts atleast the 1000 series and then and only then do you commit. And yes you need to use teh divers specified in the qual charts.
So the word quadro guarantees nothing in itself. But you are in essence paying for a better warranty thats all.
