Can't Get Mental Ray
Title says it all. I had to re-install the program, and the mental ray render option is no longer there, as well as the shaders such as dieletic material, etc. Help!
when i installed maya 7 for the first time i had to install the ahader library and mental ray all seperatly, it may be the same with you and if not then at least you can download it separatly if it came with it.
And how exacty did you manage that? Because theers no separate installer for mrentalray in maya 7. may 6 maybe? Or are you talking of mr standalone, wich is not needed either.
ANYWAY, reinstall wont work simply because it allmost never does in maya because unisntall dont unisntall your settings. Open us the plug-oin manager and load the plug mayatomr.mll/so
No nee dfor a shader library either.
QUOTE
yes maya 6 as well, and 5 in fact to.
huh mabbie i didnt have to and i just thought i did and ended upinstaling it 2 times...
