I have a Micron Millenia Max XP with Windows 2000. One evening, I installed an HP ScanJet 3300Cse as well as the software for it (HP PrecisionScan LT) as well as Adobe Photoshop 6 and WinZip. I also installed Adobe PhotoDeluxe Home Edition, Adobe Type Manager, and Adobe Acrobat 3.0 along with the scanner software. I uninstalled PhotoDeluxe and Acrobat later. Ever since then I get an error message saying that my keyboard driver will not let me go into standby. I have tried the following.
1.Called Micron Tech Support. I reinstalled the keyboard driver. It didn’t work. The tech asked me to run something called “sfc” in Windows 2000. It wouldn’t run.
2.Checked www.microsoft.com/technet. Typed “known issues”. Didn’t see anything about scanners.
3.Called Hewlett Packard. I uninstalled PrecisionScan and unplugged the scanner. The problem persists. According to the box, the scanner should work in Windows 2000 Professional. The scanner works fine.
4.I uninstalled Photoshop. The problem persists.
5.Had a friend come over. Tried to find the right driver for the keyboard on the net. Nothing. Monkeyed around with the power management settings. Right now my monitor is set to turn off in 20 mins and my hard drives in an hour.
Should I be bugged about this. I will admit I am anal, but this is a new computer! So far, the only thing I heard that may work is to run a restore and set the computer back to its original state and then install each piece of software and see if something (if anything) is causing the problem. I have also wondered if some left over files from PhotoDeluxe is causing this. I may not have removed all of the files when I unistalled this. Or is this some sort of weird Windows 2000 thing? I was hoping that it would be less buggy than NT. Is worth my time to try to solve this or should I live with it?
