Cant Paint On Polygons
hello,
I am new at maya and I am having trouble painting my objects. I have made a space ship type object, but can not paint it.
I started with a cube and extuded its sufaces. I wonder if it has do to with the extudeing of my faces. I read a lesson on painting a dinosaur. In this lesson the 3D paint tool worked fine and Iwould like to know why it won’t work on a poloygon model I made myselff. Can someone plz help me with this?
Thank You:)
Doug
Did you try the “Make paintable” option?
Th probablye problem is that you havent made any uvmap for the ship, see if you exrtrude cartain areas are left without any uvmap. no uvmap means NO 2d texturing there.
Ah, s**t. Sorry, I thought Paint FX instead of Paint textures. Joojaa is right there. You will need an UV map. Also you will need to assign a texture and a shader to paint on. That is in the paint dialog.
Cheerio
Chris
Dunkelzan & Joojao. Thanks for the help. I still have a lot to learn about UV mapping but it sounds like the answer. Thanks again for the info.
Doug
Joojaa, what’s a good resolution to paint on objects?
512 -1024 to gemes and 2048-4096 for movies 1024 -2048 fr tv
