QUOTE(SonnyA @ 02/05/09, 01:26 PM) [snapback]300362[/snapback]
I scaled and positioned the head in the scene.
Please help, What would cause this and how can i fix it?
Scaling the object will throw off the alpha gain and offset values for the file node on the displacement.
set alpha gain to = 2.2 * here you need to put the scaleX value of the head so if it is scaled to 55 this value is 55 put a ; at the end of this line
set alpha offset to = - file1.alpha gain / 2;
