I have created some Maya text and the default size is too large for the scene. I select the entire word, press the arrow key twice. The selections in the outliner are now selected: Text_My_Name_1 Trim_My_Name_1 and I try to scale the object down and the Text and Trim don't scale at the same percentage. The trim is always larger than the text. What am I doing wrong?
To transform a whole text string: 1 Marquee-select all the letters. 2 Press your keyboard's up arrow twice. 3 You can now transform the whole string as one object.
Nope! It is not working. Any Comments. I eventually want to extrude these objects as well.
I think you may be moving the curve and the trim at the same time causing the unexpeted results. Eitehr don'y move the curve that's par tof the history or delete the history.
Gmask is right since history is on the and your selecting everything in the text the by transforming both the curves and the geometry its causing everything to double transform. so basically the curves history is affecting the geometry and then the geometry history is affecting the trims, and then they are also being transformed individually.
