What is the difference between using the insert key on the keyboard and Using the Center button???
I am used to maya, so i use the insert key in XSI with qwerty key mapping. I can move the pivot, but can never center it again.
If i use the center button in XSI i can use Transform>center pivot to bounding box. This works, but still doesn't explain the Insert key difference. They even have different icons. Am I doing something else using the insert key ???
